23 Hudson identification -- Parts Sold.
Bowgod
Can someone help me try to identify my 23 Hudson? The car has no tags and I bought it with just a bill of sale and was told it was a 23 but I'm not sure. Any help would be greatly appreciated.
Photos of the car? Serial number? Both of those would be use for folks to .0
We need a serial number. My '25 is stamped on the outside of the right frame rail between the rear axle and the back of the frame.0
1923 probably had the serial number stamped into the left front chassis rail just behind the spring mount.0
Sorry about my last comment, not sure what happened. I was posting from my phone. But if you can find a serial number, someone on here can definitely help out with identifying your car.0
longlivelance said:Photos of the car? Serial number? Both of those would be use for folks to .
I have a pic but the serial number is my issue I don't even know where to look for it is my problem.0 -
54coupe said:We need a serial number. My '25 is stamped on the outside of the right frame rail between the rear axle and the back of the frame.Bowgod said:Can someone help me try to identify my 23 Hudson? The car has no tags and I bought it with just a bill of sale and was told it was a 23 but I'm not sure. Any help would be greatly appreciated.Bowgod said:Can someone help me try to identify my 23 Hudson? The car has no tags and I bought it with just a bill of sale and was told it was a 23 but I'm not sure. Any help would be greatly appreciated.
Thanks everyone I will look in these location and let you know if I find anything and here are a few pics.0
It could be 1923 to '25. Definitely not earlier.0
Thanks everyone I found the numbers they are 566234 what should be a 25 model O is this car considered a sedan or a coach0
Based on the serial number, your car is a 1925 Model O. No other vehicles are listed in 1925.
1925 Model O serial numbers are 562016 to 672227.
I believe it is a coach, but someone who knows 1925s better could step in.0 -
The swage marks on the fenders show its a 1925 or 26. 1924 had smooth fenders. Sounds like Lance is correct.0
what I've found it's a 25 but can someone tell me is this a sedan or coach0
longlivelance said:Based on the serial number, your car is a 1925 Model O. No other vehicles are listed in 1925.
It is a coach. The next model in 1926 had an all steel Hudson-built body.0
Thanks Geoff I appreciate all your help0
There was an individual selling a nice set of headlights here that look correct for your car.0
All parts are sold and I'm not sure how to remove my post0
I added "Parts Sold" to your title -- hope that helps. (Speaking as a moderator, we don't tend to remove discussions once posted, but we can modify them to indicate that the discussion is closed.)
- 85 Hudson 1916 - 1929
- 11 Upcoming Events
- 74 Essex Super 6
- 28.4K HUDSON
- 990 Street Rods
- 72 Hudson 8
- 591 Vehicles
