Moderators please address this
            Not sure I understand (that's not unusual, LOL!). I can copy and paste any posted sentences to (for example) an e-mail or an MS Word document. Are you saying that there should be a way to cut and paste an entire discussion by pushing a button or something?
            Jon-I believe cut and past links, is his intention. I have trouble with that too from time to time and often takes 3 or 4 tries to get the link to "stick" to my post.0
http address links.
If I find something on a different forum and copy the address , then try to paste it here it won't
work.
This has been since the latest forum format started
Jon , I see you link the same things from AACA that I try.
Several others have mentioned that they can't show a link.
I'm guessing something blocking it?
I can put the same link on any other forum I go to.
            SEEMS TO WORK JUST FINE....
HIGHLIGHT THE LINK THEN COPY VIA CTRL C
PASTE THE COPIED LINK TO YOUR POST VIA CTRL V
1 -
http://forums.aaca.org/f119/1952-hudson-owners-manual-380799.htmlhttp://forums.aaca.org/f119/1952-hudson-owners-manual-380799.html
OK , tried it. says web site can't be found when I click on it , if I click on second portion at htmlhttp it appears
** if you do not see 'paste' when you right-click in the text area (and I do not, at least not in Internet Explorer), just use the CTRL-V (Press CTRL and the 'V' key) to paste-in something that you have copied... **
'Key' sequences (vice the right-click & 'copy' & right-click & 'paste)':
- Highlight what you want to copy, and then press "CTRL" and "C";
- Put the cursor where you want the copied item to go, then press "CTRL" and "V";
 - 111 Hudson 1916 - 1929
