Moderators please address this
lostmindlostmind Posts: 1,220Expert Adviser
edited December 2014 in FORUM - Instructions & Tips
Why can't we cut and paste to this forum.
Several of us have asked and mentioned it in posts.
It's difficult to share when the links won't stick
  • Jon BJon B Posts: 6,902Administrator
    Not sure I understand (that's not unusual, LOL!).  I can copy and paste any posted sentences to (for example) an e-mail or an MS Word document.  Are you saying that there should be a way to cut and paste an entire discussion by pushing a button or something?
  • RL ChiltonRL Chilton Posts: 5,125Administrator, Moderator
    Jon-
    I believe cut and past links, is his intention.   I have trouble with that too from time to time and often takes 3 or 4 tries to get the link to "stick" to my post.
  • lostmindlostmind Posts: 1,220Expert Adviser
    http address links.
    If I find something on a different forum and copy the address , then try to paste it here it won't
    work.
    This has been since the latest  forum format started
    Jon , I see you link the same things from AACA that I try.
    Several others have mentioned that they can't show a link.
    I'm guessing something blocking it?
    I can put the same link on any other forum I go to.
  • TOM-WA-TOM-WA- Posts: 625Senior Contributor
    SEEMS TO WORK JUST FINE....
    HIGHLIGHT THE LINK THEN COPY VIA CTRL C
    PASTE THE COPIED LINK TO YOUR POST VIA CTRL V
    http://forums.aaca.org/f119/1952-hudson-owners-manual-380799.htmlhttp://forums.aaca.org/f119/1952-hudson-owners-manual-380799.html
    OK , tried it. says web site can't be found when I click on it , if I click on second portion at htmlhttp it appears
  • 46HudsonPU46HudsonPU Posts: 556Administrator
    ** if you do not see 'paste' when you right-click in the text area (and I do not, at least not in Internet Explorer), just use the CTRL-V (Press CTRL and the 'V' key) to paste-in something that you have copied... **
    'Key' sequences (vice the right-click & 'copy' & right-click & 'paste)':
    - Highlight what you want to copy, and then press "CTRL" and "C";
    - Put the cursor where you want the copied item to go, then press "CTRL" and "V";
