Hudson eight 34 crankcase bolt
Tapez votrI recently dismantled the housing of my Hudson survivor of 34.This vehicle has never been disassembled I precise. I have removed the crankcase; cleaned and repainted. I removed the bolts which was very greasy. While cleaning; I realized that 6 of the bolts had a brass washer and the others did not. Do they have to be mounted in a well-specified place? If you could answer my question;thank youe message
By the way, have you received the hubcaps yet ?
The UK-NZ mail must be awfully slow ! Please let me know when they arrive.
This weekend, I'll go around the pan putting a copper washer on each bolt in turn and see if that stops the leaks.
So I will temporarily drain the oil and fit a copper washer and then put the oil back in (it has only done about 25 miles).
I read that you can PTFE tape on oil pan plugs - is this correct ?
I've put my name down for a set.
Dale Cooper
Installation of the crankcase next week. Today it was valve adjustment
the 31 crankcase bolts. With both long for the oil sump
