TV cable to Carter carb
Does anyone have any pictures or ideas for the bracket I need to build? Just looking for a starting place instead of reinventing the wheel.
If you have pictures of at twinH or single carb setup either might be helpful to me.
Much appreciated.
Dan
            I am working on getting a couple of photos for you. I’ve done one with the factory 2 bbl, and one with a 4bbl. I will probably email them to you, as I have difficulty posting photos here.0
Ive put a 200R4 OD behind a Hornet Twin H Mtr then made a bracket that hooked to the Linkage. I ensured that at full throttle the cable was fully extended by Raising an 'Arm' little higher then the Twin Carb Crossshaft. Its in a '37 and don't know if could get a good pic. with GM Booster, etc hiding it.
Then later (this yr) I read an article in HR Mag on the TV Cable that details the Cable bracketry then compared with my earlier install but didn't change anything. It describes a Universal Cable Adjustment Kit to purchase. (Goggle HRM to find the article). Its about 4 pgs but the main point is to have cable fully extended @ WOT. I have it in my Documents saved but its long to Post.
Actually, just 'goggle' 700r4OD transmission cable adjustment will give you several Videos of tips
            I'm still working on getting the photos. He was out of town, and should be back today.0
            11:10 am Tuesday. Just emailed photos of the kickdown bracket I made for the factory 2 barrel manifold. Please post them here, if you can.0
            Thanks Dan, When I installed this bracket, I eliminated the lockwashers so that I wouldn't have to change the studs.0
 - 111 Hudson 1916 - 1929
 - 92 Essex Super 6
 - 178 The Flathead Forum
 - 606 Vehicles
