TV cable to Carter carb
schillaz
schillaz Expert Adviser
I am hanging a 700r4 behind a 262 and need to come up with a bracket for the TV cable from the trans to the carburetor.
Does anyone have any pictures or ideas for the bracket I need to build? Just looking for a starting place instead of reinventing the wheel.
If you have pictures of at twinH or single carb setup either might be helpful to me.
Much appreciated.
Dan
  • I am working on getting a couple of photos for you. I’ve done one with the factory 2 bbl, and one with a 4bbl. I will probably email them to you, as I have difficulty posting photos here.
  • Ol racer
    Ol racer Senior Contributor
    edited December 2019
     Ive put a 200R4 OD behind a Hornet Twin H Mtr then made a bracket that hooked to the Linkage. I ensured that at full throttle the cable was fully extended by Raising an 'Arm' little higher then the Twin Carb Crossshaft. Its in a '37 and don't know if could get a good pic. with GM Booster, etc hiding it.
    Then later (this yr) I read an article in HR Mag on the TV Cable that details the Cable bracketry then compared with my earlier install but didn't change anything. It describes a Universal Cable Adjustment Kit to purchase. (Goggle HRM to find the article). Its about 4 pgs but the main point is to have cable fully extended @ WOT. I have it in my Documents saved but its long to Post.
  • Ol racer
    Actually, just 'goggle' 700r4OD transmission cable adjustment will give you several Videos of tips
  • I'm still working on getting the photos. He was out of town, and should be back today.
  • 11:10 am Tuesday. Just emailed photos of the kickdown bracket I made for the factory 2 barrel manifold. Please post them here, if you can.
  • schillaz
  • Thanks Dan, When I installed this bracket, I eliminated the lockwashers so that I wouldn't have to change the studs.
