1946/47 hood trim installation
Lklemm1Lklemm1 Posts: 57Member
I need to put the trim back on the side of the hood on my 47. There is square holes in the hood with square clips. Do I put the clips on the hood and try to sample the trim over. Or put the clips on the trim and try to install? What's the trick. It's new paint!!!!
  • 29sptphaeton29sptphaeton Posts: 212Member
    Go to a body shop supply with one of your moldings and match up the clips. They have small universal clips with nuts on the back that fit. You slide the clips into the back of the moldings and put them on the hood and install the nuts from the back. Small flat washers may be needed.
