Removing rear wheels 1923 Hudson
Trying to remove the rear wheels on my 1923 Hudson. I am using the wheel remover but have tightened it as far as I can and no movement. Is there a trick to get the wheel loose?
Can I use a mallet and a piece of 2x4 on the inside of the wheel to get it loose? Any help would be appreciated. I need to check the bearings and grease and seal. Having no problems at present but don't want to cause any taking the wheel off.
Robert
  • You are using the correct hub puller? The one that screws on to the hub with a center threaded bolt that fits into the dimple on the center of the axle? I use penetrating oil and the original puller and have never had an issue. I would not touch the wooden spokes or outer steel rim with any hammer or other devise. These old wooden wheels don't like any type of hard shock. if you need a picture of the correct puller let me know.
    Jay
  • Some heat around the hub will be helpful, plus a whack with big hammer. The axles butt together, so you cannot damage the differential.
  • Thanks Jay and Geoff,
    Yes I have the correct hub puller and I did not plan to hit the wooden spokes. Using a little heat and hitting the hub are great ideas.
    Robert
  • Hit the wheel puller bolt when you have it as tight as possible (not the hub).
  • A very "Heavy" dead blow hammer ( 8 lbs) works better than a lighter hammer swung harder. Slow and Easy is the Word.
