52 Hornet rear brake drum max diameter
dave11
Time to replace the rear brake shoes, one of the drums is scored.
Anyone know the maximum diameter these can be turned to?
Dave
Dave
I don't have the spec. FWIW since it's a rear drum I'd kiss it with the turner and go. My premise is that you're not road racing or constantly navigating 6% downgrades. The fact that new rear drums are not available also factors into why I wouldn't shave much off.
So, apparently the maximum oversized diameter is typically stamped on the rim of the brake drum. Not so with the Hudson drums ( at least not on the ones I have) Nor does the Hudson service manual list this specification.
A google search however revealed that the standard turning oversize for a 15” drum is .060” with the wear limit (discard size) is +.090”.Dave0 -
Correction! meant to say 11" drum not 15"
Dave0 -
Good reference info. I'm hoping someone else chimes in here to inform us that new replacement drums are indeed available from such and such source. I don't think there is an alternative replacement but hope I'm wrong...
The following is a website for a company that installs replacement brake surfaces in brake drums. https://www.jgrelining.com/ There are a number of these companies located in the USA... a google search will produce others.0
Thanks Glowplug. I didn't know that such a solution existed. Goes to show one can learn something new everyday. Have you used this company for Hudson drums?
StepUp, I have not, but I have an acquaintance with much rarer drums lined for a classic vehicle. The owner was pleased with the results.
- 102 Hudson 1916 - 1929
- 17 Upcoming Events
- 90 Essex Super 6
- 28.5K HUDSON
- 992 Street Rods
- 172 The Flathead Forum
- 76 Hudson 8
- 597 Vehicles
