Overdrive solenoid issue
dave11
I am afraid I have an issue with the overdrive solenoid on my 52 Hornet. The symptoms are it will not engage. I have followed all the diagnostics for the electrical components found in the Hudson service manual, all is well with the exception of the solenoid.
When I apply 6 volts to the #4 terminal ( engage circuit) on the solenoid the plunger extends as it should.
However if I then apply 6 volts to the #6 terminal
( maintain circuit) then remove the current from the engage terminal the plunger retracts?
I have looked at the contact points on the solenoid, these appear to be fine.
Before I source a replacement solenoid, I’m hoping that someone with more experience can check my diagnosis and advise.
Dave
Dave
No. 6 terminal should not have voltage on it, it is a ground source for the ignition coil during a "kick-down" operation.0
Thanks Geoff,
So you are saying that #4 terminal has current applied as long as the solenoid is engaged as in overdrive?0 -
Yes, that is correct. To be more accurate, it has voltage applied, which causes current to flow. There is an internal set of contacts which energise the hold in coil, and opens the pull in circuit. The pull-in is a very heavy coil that takes a high current, and once energised the hold in coil takes a very small current.0
So I have to ask,....If the hold in coil was bad, would the solenoid pulse back and forth or chatter??
Dave0 -
Yes it would.0
Thanks Geoff, you have saved me the cost of a replacement solenoid.
Merry Christmas to all
Dave0
- 85 Hudson 1916 - 1929
- 11 Upcoming Events
- 74 Essex Super 6
- 28.4K HUDSON
- 990 Street Rods
- 72 Hudson 8
- 591 Vehicles
