1949 Hudson 8 starter bolts
Following.0
I just received two of the starter mounting studs from Wildricks for my 35 T as the originals were cross threaded at some point in the past per the attached pic. Not sure if they are the same part used in 49 but they may have the correct ones you need.0
Check your email0
Thank you , I will check.
- 85 Hudson 1916 - 1929
- 11 Upcoming Events
- 28.4K HUDSON
- 990 Street Rods
- 71 Hudson 8
- 592 Vehicles
