1950 pacemaker head
2manyprojects
do some 232 heads have 232 on them and others have 500 on them ? why ? thank you
The 500 designates it for a narrow block engine 232. The 232 head is for the wider block 232. The wider engine block came out in 1951 to accommodate the Hornet bore size and coolant passages.0
500 was for 1950 only, (narrow block) 232 from 1951 to the end.0
THANK YOU0
The wide-block was developed to allow for Hydramatic trans to Hudson engine bell housing. Both I6 (all models including Jet) and I8 blocks from '51 to '56 used the wide block design (51 and 52 for I8)
50C8DAN said:The wide-block was developed to allow for Hydramatic trans to Hudson engine bell housing. Both I6 (all models including Jet) and I8 blocks from '51 to '56 used the wide block design (51 and 52 for I8)
Learn something every day.
Thanks0 -
which 232 head wide or narrow do guys put on 262 motors?0
This is a good read for anyone wanting to know the details and time lines on the engines and blocks. https://www.jalopyjournal.com/forum/threads/hudson-232-262-308-engine-tech.539734/
Note that wide and narrow heads must match the correct wide and narrow blocks, they do not interchange! The only year for the 232 narrow head is 1950, and are marked with 500, so only 232 and 262 blocks from 1948 thru 1950 can use this head. Anything after 1950 will need the wide head on the wide 1951 - 1956 blocks.0
Jack Miller once had a 50 narrow block with a wider head on it. Hung over on the drivers
side of block. It was a running engine.
No idea which gasket was used.0 -
The factory provided replacement heads for the narrow block engines which used wide block castings but machined for the narrow block. That is probably what Jack had.0
Ric West IN said:The factory provided replacement heads for the narrow block engines which used wide block castings but machined for the narrow block. That is probably what Jack had.
Thanks0
- 85 Hudson 1916 - 1929
- 11 Upcoming Events
- 74 Essex Super 6
- 28.4K HUDSON
- 990 Street Rods
- 72 Hudson 8
- 591 Vehicles
