Overdrive solenoid installation issues
1946 R9-B1 trans OD. I’m having a devil of a time trying to get the solenoid pawl installed in the slot. I’ve attempted inserting per the instructions (90 deg insertion and rotate) but it just won’t go into place. I have another R9 OD and it installs fine in that unit. Ive visually inspected both of my units and I can’t see any difference. Any words of wisdom from the Hudson hive?
thanks in advance
thanks in advance
There are two different length shafts. Take a jumper wire and battery and measure the length of the shaft. The solenoids look identical except for the shaft.0
Thanks. This solenoid unit was working in the other identical trans OD. I pulled that one out due to a broken tooth on the low/reverse gear. I’ve taken the spacer off and still can’t get it to hook in the slot0
- 85 Hudson 1916 - 1929
- 11 Upcoming Events
- 74 Essex Super 6
- 28.4K HUDSON
- 990 Street Rods
- 72 Hudson 8
- 591 Vehicles
