Drive-Master
The 1948 mechanical procedure manual states when the accelerator pedal is depressed the car moves forward in pick-up gear and shifts into high gear when pedal is released.Are they referring to second gear when using the word pick-up gear as it sounds like it only shifts once.
Thanks
Thanks
No, they're referring to the "kick-down" switch (under the gas pedal) disengaging the overdrive to increase the engine RPM temporarily.0
48Sed. Yes you’re correct. With Drivemaster, “pickup” gear is second.James P - the kick down switch is for Overdrive only0
OOPS, sorry. I stand corrected and educated, too.0
- 103 Hudson 1916 - 1929
- 18 Upcoming Events
- 90 Essex Super 6
- 28.5K HUDSON
- 557 "How To" - Skills, mechanical and other wise
- 992 Street Rods
- 172 The Flathead Forum
- 77 Hudson 8
- 597 Vehicles
