info
Hello everyone is there a spring that goes on the cable that goes to the transmission that is used for first and reverse??
redrider, it may help if you describe what type car you are asking this about. Year and model0
1948 super sox Ist & reverse shift cable, should it have a spring connected to it?/0
There isn’t one on my 46 coupe and it’s the same set up on your stepdown. There is a rubber boot on each end to protect the Bowden cable. Also check the condition of the shift rod rubber bushing. Wildrick has them if yours is deteriorated. Adjustment is covered in the mechanical procedure manual.0
Thans everyone for your help..0
- 85 Hudson 1916 - 1929
- 11 Upcoming Events
- 74 Essex Super 6
- 28.4K HUDSON
- 990 Street Rods
- 72 Hudson 8
- 591 Vehicles
