wheel removal
i have a 28 Essex drivetrain and i am trying to remove the rear wheel driver side, previous owner also tried by the evidence of hitting the threaded part with some blunt object, today i heated the dickens of the threaded part in hopes of expanding the housing so i can remove the wheel/drum assembly, no luck.. yes i have been using wd40 for some time in the summer and some penetrating oil..... any advice.. i have a hub puller that i almost had on and almost ruined the threads on it, i'm thinking wrapping a chain around the spokes and using a jack-all... BUT i can almost imagine ending up with a bunch of firewood and coming back here for better advice...SO the chain experiment is on big time hold.... any advice??
You definitely need a wheel puller that screws on to the hub cap. Any attempt to wrap a chain around the spokes will break the spokes, as you suspect. As a last resort, jack up the opposite side of the car, leaving all the weight on the side you want to remove. undo the nut a few turns, but not past the end of the thread. Using a heavy piece of bronze as a absorber, and to prevent mashing the end of the axle, hold this against the end of the axle and give it a good whack with a 10 pound hammer. Have you tried driving around with the nut loosened?0
unfortunately it is only a drivetrain frame and non running motor on blocks, driving is NOT a option.. i will add a few pictures (somehow) tomorrow...0
As a last resort , maybe you could drill and tap two holes in that hub and use a good two jaw puller with holes in the legs. Threads look pretty rough there.0
yikes
- 85 Hudson 1916 - 1929
- 11 Upcoming Events
- 74 Essex Super 6
- 28.4K HUDSON
- 990 Street Rods
- 72 Hudson 8
- 591 Vehicles
