6V pos grnd tach
50C8DAN50C8DAN Posts: 2,413Senior Contributor
This guy is modifying new tachs for 6V pos (or neg) ground.
https://www.ebay.com/itm/194324584733?hash=item2d3ea5d91d:g:sLEAAOSwjY5g-yBs
Better than the vintage SW tachs that go for $500 and up.
  • superwaspsuperwasp Posts: 230Member
    Pretty cool. Too bad they look like a cheap auto parts store tach.
  • 50C8DAN50C8DAN Posts: 2,413Senior Contributor
    Yep beggers can't be choosers as they say!
  • eddiehudsoneddiehudson Posts: 47Member
    Unmodified ones are $62 on Amazon
    Part of me suspects the guy simply found a tach that has internals that function on a voltage range from 5-16 V or something of the like. A lot of electronics will function on lower voltages than we feed them. I wouldn't be shocked if the "unmodified" one could be dropped in and function if you wire to the system in the right polarity.
