Front Wheel bearings for a 1923 Hudson
My Hudson uses 415 and 315 Timken wheel bearings. I have been able to find some 415's but can't seem to locate any 315 bearings. Does anyone know what other bearing number would replace the 315?
Robert
I mentioned I have a complete set, but will be dear as I want to sell them all. Get an electronic copy of the Timken brg book. Plenty of brgs there that you can use. You may have to get a machine shop to make and install a sleeve to use a smaller diam brg, or better get them to bush the stub axle. The stub axles always seem to wear more. Sometimes the only difference in bearing numbers is a radius. Good luck0
Hello Barry willing to buy your complete set. Do you have more than one?One of my friends said that the bearings need a race. I don't see a race in the old bearing that I removed. Is it possible that the race is embedded inside the wheel hub and I don't see it? Or does the wheel hub act as the race?Robertrhurst@nternet.com0
- 85 Hudson 1916 - 1929
- 11 Upcoming Events
- 74 Essex Super 6
- 28.4K HUDSON
- 990 Street Rods
- 72 Hudson 8
- 591 Vehicles
