piston rings
does anyone know where i can locate a ring file to adjust my rings to fit each cylinder
  • ratlee2
    ratlee2 Expert Adviser
    edited November 2020
    I purchased this one from Summit Racing and used it a couple of times.  Does a good job of keeping the filed edges square.
    https://www.summitracing.com/parts/sum-906795
  • Hans
    Hans Senior Contributor
    for pined rings?
  • my engine is a 55, 308, that will be bored for bigger pistons. the pistons were destroyed to be removed. this engine was rusted in the cylinders.
     are these rings pinned or loose on the pistons? the ones that i was able to salvage were loose, i do believe.
  • BigSky
    BigSky Senior Contributor
    Modern pistons & ring package will do wonders for the 308!
