Engine
raycox
Essex 6 plugs oiling badly would the cause of that be the gap in valves i have changed the spark plug from ngk -- Bosch your advice would be appreciated motor would not done 1000 mps since overhaul thanks
Do a compression test of each cylinder.0
The valve clearance will have no effect on plug oiling. the only thing causing this is too much oil getting past the rings. You may need to use a non-detergent, non friction-modified oil until the rings bed in.0
What is the actual spark plug numbers you were using???
Both for the NGK and the Bosch??
Plugs that are to cold will foul easily.
There is a likely hood that a hotter range may help0
- 85 Hudson 1916 - 1929
- 11 Upcoming Events
- 74 Essex Super 6
- 28.4K HUDSON
- 990 Street Rods
- 72 Hudson 8
- 591 Vehicles
