47 electric wiper conversion
I am putting electric wipers in my 47 brougham and would like to use the original dash knob to control it. Has anyone done this and what motor did you use? I have all the stock hardware and am wondering if there is a kit or motor that would work. Thank you for any help you can give me.
Ive done '37's and 47's. Just Goggle Universal Wiper Motors either 6 or 12V. Remove spring Clip & Arm from Vac Mtr, then put a short piece 1/8 angle, drill 3 holes then attach across the orig wiper mount holes. Need to cut & shorten the Electric Mtr then attach the Vacume Mtr Arm. They now have two Spd Mtrs and could wire to an Intermitten switch. One Unit I bent a tiny rod up to the Orig Switch. Its late, so find & post pic tomorrow.
I have been thinking on this conversion also. Looked at Newport wipers and another brand of hot rod stuff. About $250 for everything but the dash switch was a question mark. Will watch with interest0
The switch that Newport uses will allow use of the OEM Hudson knob.0
Attached Universal Wiper Motor using your Hudson Link. About $50. if your handy takes a few hrs. I ran a rod from the wiper motor up to my '37 switch, on the other I installed a modern dash switch. The Newport is probably better since ready to install. I installed a CD/FM Radio that's small so unsure if stock radio clears.
The next question which will result in opinions, is the electric that much superior to a good vacuum system?0
A good question and agree sure to get pro & con's. Ive always been told by Experts (that are gone now) to always remove dual action pump since 'might' leak gas into the oil pan or leak oil out. However, a Vacume Reserve Tank might be an Excellent Idea to aid vacume wipers.
Hello,
What are the thoughts on using a Trico electric vacuum pump to run the wipers?
Take care,
Steve Bryson
- 85 Hudson 1916 - 1929
- 11 Upcoming Events
- 74 Essex Super 6
- 28.4K HUDSON
- 990 Street Rods
- 72 Hudson 8
- 591 Vehicles
