Carb Fuel Bowl Corrosion
I just finished rebuilding the carbs on my 53 Hornet. The engine is a 308 from a 55 with twin H. There was some pitting in the bottom of the fuel bowl and it is now dripping out of a pin hole on the side near the bottom. Is there anything I can use to fill the pits inside the bowl that would stand up to gasoline or do I need to source a new carb bowl?
JB Weld. Used it a few times to fix floats.0
I'll give the jb weld a try.0
POR15 fuel tank treatment would work as well.0
- 85 Hudson 1916 - 1929
- 11 Upcoming Events
- 74 Essex Super 6
- 28.4K HUDSON
- 990 Street Rods
- 72 Hudson 8
- 591 Vehicles
