'39 gas tank factory ohm readings?
7XPacemaker
Does anyone know what the factory sending unit should have been? Someone has fabricated the tank on my car and it is a side mounted sending unit (perhaps an old Jeep sending unit).the sending unit is shot and the plastic float is full of gas. I want to order one that will work with the original gauge. The one that is in it looks similar to one from a '46 Willys Jeep.
The original unit is a bi-metal one, not resistor. The later ones used a 90 ohm resistor, but need to be stabilised at 5 volts to work properly.0
- 85 Hudson 1916 - 1929
- 11 Upcoming Events
- 74 Essex Super 6
- 28.4K HUDSON
- 990 Street Rods
- 72 Hudson 8
- 591 Vehicles
