1949 commodore 8 rad needed
2nevets
Does anyone if the Aluminum ones on the internet that fit from 52-54 would work?
thanks in advance
thanks in advance
Steve
All stepdown radiators 48-53 will interchange . 1954 has slightly different locations for connecting it to the U channel but it will work. The thing you need to watch out for is using a Pacemaker or Wasp( 232) radiator in a LWB Hudson. They have less cooling capacity than the bigger cars (262,254,308) Generally speaking 48-51 have the square tops and 52-54 are the round top radiators. The 8 cylinder cars don't use the small shroud on the front tie panel since the engine sits a bit more forward than the full oil pressure engines so the 'L' brackets for attaching are reversed .0
thank you0
- 85 Hudson 1916 - 1929
- 11 Upcoming Events
- 74 Essex Super 6
- 28.4K HUDSON
- 990 Street Rods
- 72 Hudson 8
- 591 Vehicles
