Removing bearings on Hudsons and Terraplanes
barrysweet52
Photo shows a simple tool I have made from thick tube. Distance between front 5/16 threaded holes is different to the holes at the back. Bearing block is a tight fit so its important to pull block out vertically - I used a caliper to check the starting clearance then wound the end bolts the same number of turns. Could have welded a nut under the tube but just used a spanner. I used a scrap piece of steel under the end bolts so that it didnt damage the crankcase. I very quick easy job. Hope its of interest and will help someone.
Clever idea, thanks for sharing.0
Thanks for sharing Barry.0
- 85 Hudson 1916 - 1929
- 11 Upcoming Events
- 74 Essex Super 6
- 28.4K HUDSON
- 990 Street Rods
- 72 Hudson 8
- 591 Vehicles
