Hood hinge
Do you mean the stainless centre cover strip that Mack and MGs used?0
That's right Barry. Unfortunately Mack and M.G. parts suppliers are about as plentiful as Hudson! The one I have is badly corroded, so need a new one. It is a domed strip with folded un der edges which the hood (bonnet) sides fit into longitudinally0
Geoff,
I don't know what size you are looking for but I have used Max Merritt to make new ones for my Packard. They aren't specifically for Packards.
John Forkner
http://www.maxmerrittauto.com/showpage.php?page=body-molding.htm
They make a stainless steel repro strip for Fords of the 1930's. These are supplied in 48" lengths. Here is the web address https://grumpsgarage.com/product/1932-36-center-hood-hinge-strip-universal-stainless/
Here's a similar one that's supposed to fit 1930's Dodges and Plymouths -- might even be the same one. Also 48" long. http://www.srpmstreetrods.com/srpm/mopar-hood-hinge-center-strip-ff8081812db6a293012dbe0e3cd504d5-p.html://
Of course you'd want to get some tight measurements before ordering.0 -
Thank you, thank you! That looks exactly like the one on this '36 Hudson. I'll pursue those links.
Geoff
If you still need one after the above give me the part number and I will contact our local Mack dealer. I was lucky there before.0
Thanks, I have ordered one from Grump's Garage. Your help is much appreciated.0
Wildrick Rubber etc have the part you need - 1933 - 37 Hudson and Terraplane
Hood Hinge Stainless Steel 48" Long Cut to Fit. $85.00 PN434
It's on the page under Hood Items and Trim Retainers
home hood support
- 85 Hudson 1916 - 1929
- 11 Upcoming Events
- 74 Essex Super 6
- 28.4K HUDSON
- 990 Street Rods
- 72 Hudson 8
- 591 Vehicles
