1952 Hydramatic swap to manual help?
Monkeyspinner
The '52 Wasp Hollywood i have just bought is an automatic and i dislike automatic transmissions, even in modern cars.
How easy is it to change to manual? ideally I'd like something like an S10 T5 but open to suggestions. I want a nice tall cruising gear.
I understand that Wilcap used to make an adapter kit but they stopped... is there anyone else making a decent kit?
I am happy to fabricate the clutch pedal assembly if I have to, or is this something that will simply bolt in from a donor car that is breaking for spares?
Thanks in advance for any help.
Tim .
Tim .
Is this the 55 engine? Does it have a 55/56 crank?0
54coupe said:Is this the 55 engine? Does it have a 55/56 crank?0
Randy Maas has made them at 21St Century Hudson and Willcap makes the adapter with flywheel... Bendtsen Speed Gems may too.
https://transmissionadapters.com/collections/hudson-308
http://wilcap.com/hudson.html
Here is a Person that made a Dry clutch, Linkage, and Adapter, for a T6 into a Hornet for a Club Member in Cleveland.... They have mated other Vintage Flathead 6's with Standard Tranmission and apparently enjoy the challenges.....Vintage MetalworksAtwater Ohio 330 322 3102
dfarwell09@gmail.com
Discussion
https://openforum.hetclub.org/discussion/152562/transmission-adapters/p1
- 85 Hudson 1916 - 1929
- 11 Upcoming Events
- 74 Essex Super 6
- 28.4K HUDSON
- 990 Street Rods
- 72 Hudson 8
- 591 Vehicles
