clutch kits
blondwookie
Does anyone know if there is any other clutch disc and pressure plate i can use on my 55, 308, besides the factory clutch asembly
why would you want to change it up ?0
I'm a retired mechanic, and known for updating some things0
I understand the dry plate clutch on the '55-'56 Hash models is a standard Borg and Beck unit same as used on Studebaker, Mopar, and other vehicles. It is identical with the Jet one as well, but not sure if the flywheels are the same.0
if i can learn the minimum thickness and the maximum thickness of the 10 inch flywheel, for my 55, 308, i may have a machinist make me a billet steel flywheel that will Borg and Beck clutch assembly
- 86 Hudson 1916 - 1929
- 11 Upcoming Events
- 74 Essex Super 6
- 28.4K HUDSON
- 990 Street Rods
- 72 Hudson 8
- 593 Vehicles
