Steps for installing cork clutch.
Rob Fayette
Rob Fayette Expert Adviser
Does the new cork clutch from Doug Wildrick have to be soaked before it's installed.  If so, what do you soak it in, and for how long?
Thanks,
Rob
  • Geoff
    Geoff Senior Contributor
    Shouldn't need soaking, but a wash-over with clutch fluid before installing will ensure that it does not stick to the surface of the flywheel or pressure plate.
  • Rob Fayette
    Thanks Geoff.  I will do that.
    Rob
