Gaskets
Who supplies the 32-33 Terraplane 6 valve cover gaskets. Dale C doesn't respond.
Can you give the dimensions of what they should be? I have a couple of cork valve cover gaskets that are decent but unmarked as to what they belong to.0
Apx 10.5 X 3.750
If you can't locate, buy a sheet and cut your own !! This Co has lots of stuff !!
https://www.mcmaster.com/cork-gasket-sheets
I don’t know how often Dale Cooper checks his email? But he always answers the phone and he has those gaskets.0
You can buy sheets of gasket/Cork in many thickness from most auto supply shops for a few dollars. Buy a picture border plastic cutter board and away you go using the razer to make any gaskets for next to nothing for the rest of your cars life. You can also use the old gasket as a template. Much more fun than just ordering a die-cut gasket and a lot less dollars cheers ken
I have a set that is approx 10.750" X 3.750". If you think this may work let me know.0
I'm sure that would work Lance!0
If they are a match, I'll use them as patterns to make copies for future use.0
OK great. Give me a call. 704 792 911zero.0
- 85 Hudson 1916 - 1929
- 11 Upcoming Events
- 74 Essex Super 6
- 28.4K HUDSON
- 990 Street Rods
- 72 Hudson 8
- 591 Vehicles
