Overdrive trans.
hudsonsplasher1
Hi all,
what's a good weight of oil to use in a 49 overdrive? I'm changing the oil and don't want to use something too heavy.
Thanks,
Gene.
Thanks,
Gene.
www.royalpurple.com/product/max_gear/
Royal Purple Max Gear 75W-140 is a non-corrosive lubricant you can use in the transmission and rear axle. It meets the GL-4 and GL-5 specifications. I use it on my '51 Stepdown. It was recommended in either this or the member forum a while back. The overdrive uses the same oil as the transmission.
cchancel said:www.royalpurple.com/product/max_gear/
Royal Purple Max Gear 75W-140 is a non-corrosive lubricant you can use in the transmission and rear axle. It meets the GL-4 and GL-5 specifications. I use it on my '51 Stepdown. It was recommended in either this or the member forum a while back. The overdrive uses the same oil as the transmission.0 -
Here is a discussion on the same topic.
https://openforum.hetclub.org/discussion/comment/221725#Comment_221725
- 85 Hudson 1916 - 1929
- 11 Upcoming Events
- 28.4K HUDSON
- 990 Street Rods
- 71 Hudson 8
- 592 Vehicles
