Geoff Clark
have not received any email from you Val. My email address is NZgeoffclark@xtra.co.nz but leave the first NZ off, it just to fool the autobots.0
Geoff,
If you like or want to could you edit your user name to remove the "," from it as it really confused the PM software0 -
Being only semi-literate in such matters, can you give me basic instructions please Paul.0
No problem Geoff.
At the top of any page you'll see your login name , click on this and it will open your profile page.
On there on the right hand side you'll see what looks like a profile with a down arrow.
Click that and you'll get the option to edit your profile. In there will be your user name, if you delete the comma from that and save , job done.
Any issue let me know and I can adjust it for you0 -
Okay, have checked that, and the email address is correct, so I don't know what the problem is. It is of course different from my user name.0
It's your user name that's the problem Geoff. If you look at it it's "Geoff C., N.Z.". It's the comma in there that is confusing the PM software so if someone tried to PM you what they'd see when they went to send the message is that it would try to send a message to someone called "Geoff C." and someone called "N.Z." because it uses a comma internally to separate out who the message needs to go to.
So , and this is of course your choice, if you remove the comma from user name that will stop the PM software being confused. If you don't then it just means that people can't send you a PM0 -
Okay, I've eliminated all extraneous punctuation marks and spaces, and now just have my truncated first name as my user name. Will see if that works.0
I've sent you a PM Geoff so that looks good now0
- 85 Hudson 1916 - 1929
- 11 Upcoming Events
- 74 Essex Super 6
- 28.4K HUDSON
- 990 Street Rods
- 72 Hudson 8
- 591 Vehicles
