car covers
2manyprojects
looking for recommendations for outdoor waterproof car covers. i looked online many to choose from but alot of bad reviews.
Yes there are many out there, and actually most are made by the same company. I got mine from carcovers.com, but from what I could tell they sell the same thing most of the other guys do.0
Fine for short term emergency storage, in our climate long term use will just create RUST. Good luck....0
A decade or so ago I had one of the really nice, thick & waterproof covers. After I bought it I read it wasn’t supposed to be kept on for long & that it really wasn’t too waterproof.
This may not work but if you can do any kind of canopy it would be best. If not keep an eye on the cover & moisture that develops underneath the cover. Don’t forget even soft covers will rub some if it’s wind out. Wish I had the magic bullet for you, but you’ll just have to way the pluses & minuses for your climate.0 -
I pretty much echo what everyone else has told you. Not recommended.0
budget not the issue,the city is the issue. i have as large of a building as allowed. wooded 5 acres can not see building from my private street. still they have a issue.0
Yes, a cover is not for permanent outside storage. In fla, if left on long term, it creates a humid environment and rust will result.0
i had a similar issue - upon inspection, the city saw that my small structure was actually constructed to be removable (bolted to concrete footers in the ground - it would take 2 strong guys to move) - they said removable structures didn't count - no problem since - perhaps, check your local codes for a creative yet legal solution2manyprojects said:budget not the issue,the city is the issue. i have as large of a building as allowed. wooded 5 acres can not see building from my private street. still they have a issue.
In Southern California bolting to the ground makes it permanent. So you have to get creative especially with some of the strong winds. Buckets of concrete work well as does old Hudson leaf springs. Of course the size of the structure is another issue.
Jay0 -
Solution: don’t tell the city & use CAMO!0
my wife solution was the worst advice,sell some cars.0
- 85 Hudson 1916 - 1929
- 11 Upcoming Events
- 74 Essex Super 6
- 28.4K HUDSON
- 990 Street Rods
- 72 Hudson 8
- 591 Vehicles
