voltage regulator
What is the part number?0
Standard VR20
Oh, I see it now. It looks like a good value. I also found something like what's on my car now, at double the price!
https://www.vintageautogarage.com/Prestolite-Mechanical-Regulator-6-Volts-Regulated-p/rvr2175.htm
I wonder if mine needs replacing? I don't ever use the headlights, but my AMP light used to come on when the car was running rough due to my vacuum leak. My speedometer also jumps around a lot, but I think it just needs cleaning and lubrication. I don't know if either of these things are actual symptoms of a bad regulator.
Speedometer has nothing to with voltage!0
Ha, yeah, I didn't think so. I knew they were mechanical. I just Googled the symptoms for a bad voltage regulator, and that was the first thing they mentioned, but I'm sure they were talking about later model cars with electronic speedometers.Geoff C., N.Z. said:Speedometer has nothing to with voltage!
- 85 Hudson 1916 - 1929
- 11 Upcoming Events
- 74 Essex Super 6
- 28.4K HUDSON
- 990 Street Rods
- 72 Hudson 8
- 591 Vehicles
