Front Springs
PittsSpecial
Hi,
I am going to go through the front suspension and rebuild steering and suspension bushings etc. Does anyone have any experience of changing the front springs to the heavier duty springs ? looks like 2 type are available, a std spring and a heavy duty stiffer spring ? Any feedback from people who have tried the stiffer springs would be appreciated.
Cheers
Andrew
Cheers
Andrew
What year and model car are you asking about?
hi - i recently spoke to Mark at the following link - he seemed to know his stuff regarding springs! i would give him a call - www.shocks2springs.com - hope this helps!0
Car is a 54 wasp club coupe (2 door fastback), with a 7x 308 in it. I saw the Eaton springs and that they offer options for ride and stiff ness and just wanted to see what improvement the stiffer fronts make on the car.0
A heavy duty sway bar would probably be more of an upgrade than stiffer springs...0
iceblade10 said:A heavy duty sway bar would probably be more of an upgrade than stiffer springs...0
thanks for the feedback. what diameter sway bar would be a good upgrade ?0
Interesting, I am also rebuilding the front suspension on my 48 Super Six 2 door coupe
and I am wondering what to do about the front springs. I already have an upgraded
sway bar to fit (from Dale Cooper).
I have been looking at the Eaton web site. They offer standard and heavy duty springs
and they also offer reduced or increased ride heights springs. I noticed that it appears
there was a change to stiffer springs part way through 1952. It seems that all 6 cylinder
models (super 6, commodore and Hornet) had the same springs in a given year.
48 - 52 Eaton Part numbers
Standard MC1796
Heavy duty MC542
52- 54 Eaton Part numbers
Standard MC542
Heavy Duty MC3512Van anyone comment if Hudson made a change to stiffer front springs during 1952 ?Has anyone any experience with either fitting heavy duty, or reduced ride height front springs.
I would be very interested to hear some direct experience regarding what difference it made. Did it make any improvements or if it made the ride too harsh.
Many thanks for any help or advice.
I am going to try the sway heavy duty sway bar and see what difference that makes and then think about spring change.0
Fitted the heavy duty sway bar and made a big difference to the car and how it handles. Great advice from everyone - Thanks.0
- 85 Hudson 1916 - 1929
- 11 Upcoming Events
- 74 Essex Super 6
- 28.4K HUDSON
- 990 Street Rods
- 72 Hudson 8
- 591 Vehicles
