wheel seals for 1947 pick up.
KenF
looking for wheel seals for my 1947 big boy. I have all the bearings and races but seals are elusive.
anybody have any suggestions?
Contact Uncle Josh, he is the pickup registrar0
can you tell me how to contact Uncle Josh?0
Emailcramerlp@roadrunner.com0
Seals, Front WheelTCM15625236-54 XJetChicago RawhideCR15649National6407NAPA16246Seals, Rear Wheel InnerNational635636-54 XJetChicago Rawhide15960Victor49136National482253InnerNational5811Seals, Rear Wheel OuterVictor4921836-54 XJetNAPACR 17310RWOuter1.75ID2.437OD.250ThickSeals, Rear Wheel DanaInner40769S0
THANK YOU!
i have already tracked down the front with your help.
much appreciated!0 -
Ken F Did you get the # of the front wheel seal,and if so what is the #.
We locals have found a seal that fits the stepdowns front wheels properly. that is it will not touch the bearing but will seal on the shaft and it is a lip type seal.
The co is reproducing this seal that was in use many years back.
The part # is SKF 15649 and made in the USA.
hope this helps. Rudy B.0 -
using Uncle Josh's information here is a
FRONT SEAL UPDATE:
S) O.D. - 2.502" M) 63.5 mm
S) I.D. - 1.562" M) 40 mm
S) width - .250" M) 6.35 mm
Timken/Federal Mogul/National
40185 (leather)
42364s (nitrile)
SKF/CR
15649
these parts are getting hard to find.
METRIC ALTERNATIVES:
Hi tech seals OS40627
Volvo 140246627
Claas 02122230
Case IH E7146035
Simmerring 12003802B
Thanks Ken, if i would have looked above i should have seen the info on seals.
Rudy.0
- 85 Hudson 1916 - 1929
- 11 Upcoming Events
- 74 Essex Super 6
- 28.4K HUDSON
- 990 Street Rods
- 72 Hudson 8
- 591 Vehicles
