6 volt electric fuel pump
hudsonsplasher1
Looking for recommendations for a 6 volt fuel pump for my step down. They're lots of options on ebay.
I am a fan of the Carter (P 4259 I think) as its only a get fuel to the carb after sitting a while/backup/vapor lock pump. And the regular pump has no problem pulling fuel through it when its not on.
Jeff
jjbubaboy said:I am a fan of the Carter (P 4259 I think) as its only a get fuel to the carb after sitting a while/backup/vapor lock pump. And the regular pump has no problem pulling fuel through it when its not on.
Jeff0 -
Here's a Speedway Motors link:
https://www.speedwaymotors.com/Carter-P4259-6-Volt-Electric-Fuel-Pumps,8837.html
The Carter needs a bypass. Yes, it does flow through at low demand, but I used to starve my engine out on hard pulls. I ended up installing a bypass with a check valve to make it work the way it should (see image). Many places carry the Carter: Amazon, Summit Racing, Jegs, etc.The Packard Club had a thorough discussion on this topic and led me to the check valve I needed:https://www.packardclub.org/forum/viewtopic.php?f=8&t=4511&start=100
NAPA also has one at less cost.NAPA Fuel PumpsPART #NNP B0110EReserve Online Price
(USD)$47.24 /EachWas $78.29Call Store for Availability
I use an AIRTEX E8011 on my Terraplanes and '49 Hudson Super Six. Been using them on my cars for a couple of decades.
It is 6 volt and can be used on both positive & negative earth systems.
I use it the same way as jjbubaboy and my mechanical pump has no problems in pulling the fuel through the Airtex (no by-pass needed).
You can buy an Airtex E8011 on ebay, or most Auto shops in the States.0 -
Thanks guys, much appreciated.0
gene, glen and i use napa got them from john pontius from his napa store. he gave us a great deal. i have them on 3 of my hudsons,no issues.0
2manyprojects said:gene, glen and i use napa got them from john pontius from his napa store. he gave us a great deal. i have them on 3 of my hudsons,no issues.0
- 85 Hudson 1916 - 1929
- 11 Upcoming Events
- 74 Essex Super 6
- 28.4K HUDSON
- 990 Street Rods
- 72 Hudson 8
- 591 Vehicles
