Wanted - Picture of Centre Bearing Holder Bracket
PeterD
Need a picture of the Drive shaft Centre Bearing Holder Bracket for a 53 Step Down. The Bracket that holds the Support Cushions.
Thank you.
Here's a pic of the drive shaft and the frame cross member where it bolts on. There may be some rubber missing on the carrier bearing, It came with the car like that. Hope these pics help a little.0
Found this part at Rock Auto, I think it takes two of them. I'll look under a car that has a driveshaft in it and take another picture tomorrow.
Thank You Triman62,
Another picture would be much appreciated. I do have the Rubber Cushions, but the bracket bolted to the Carrier bearing housing looks different on mine.
Thanks - Pete
Peter , there is a hydramatic bracket and a 3 speed manual tranny bracket. Which one do you need?0
The following pictures show the brackets that bolt to the cross member and to which the rubber shock reducers bolt.
Pictures of the 53 came out to dark, I took some pics of the 52, it has a 3 speed manual trans. It looks the same as the other pic I posted earlier, That driveshaft came with the 53 also, must be a extra part, the driveshaft is still in the 53.0
Mine is a Hydramatic. Is the picture from Oldfarmer the correct one for this. Thanks0
I don't have a hydro car for comparison, but oldfarmer has forgot more about Hudsons than I'll ever know, so I'll guess he is right.0
Yes, "Old Farmer's pics are of the Hydramatic support .0
Thank you to all for the information. The one in my Hornet is the same as triman62 has pictured, but I do have the other bracket that Oldfarmer pictured. I will change it over.
- 85 Hudson 1916 - 1929
- 11 Upcoming Events
- 74 Essex Super 6
- 28.4K HUDSON
- 990 Street Rods
- 72 Hudson 8
- 591 Vehicles
