Hornet Brake Upgrade for '37 - '54 available
There is a Pair of Hornet 11" x 2.250 Front Brakes complete with Backing Plates, Hubs, and Drums currently on E Bay. They would be a great Upgrade in stopping on '37 - '54 Hudson's with smaller lining & drums. 1937 - '47 only requires swapping one hub bearing. EBay Item #202116309880 (Not my Ad)
How much money are we talking about0
$200.......
Will also bolt up to 34/5/6 axles, still need to change one bearing.0
Ive done the large Hornet Brake upgrade on 3 Hudson now and liked the results..... I think the inner brg from the '30's & '40's has to be utilized. The Brg OD is the same Race, just the Inner diameter is different. Additionally, The '30's & '40's spindle is .125 longer so I had to use an additional 'Tang Washer' behind the Castle Nut. On one application, not having extra Tang Washers, I purchased a 'Grade 8' Washer at Lowes to insert behind the Castle nut. Works just Fine.... Dont see many complete Sets advertised so just a thought.....
- 85 Hudson 1916 - 1929
- 11 Upcoming Events
- 74 Essex Super 6
- 28.4K HUDSON
- 990 Street Rods
- 72 Hudson 8
- 591 Vehicles
