Gearshift position
After switching from an overdrive to a manual transmission, I was surprised that the gearshift positions were altered. Now first and third are no longer at 4:00 o'clock but are just below where neutral used to be. 2nd and reverse are at 1:00 o'clock instead of two o'clock and neutral is more like 2:15 instead of 3:00 oClock.. I see where I need to adjust the gearshift rod, I just didn't think that there would be such a large variation in shift pattern between the two transmissions.
You might want to mention the year, since Hudson had two after the War (their own, then Borg-Warner.
The manual transmission came out of a 48 Commodore Six sedan. I'm putting it in a 49 Super Six coupe, I strongly suspect that the engine and overdrive that is in the 49 came from a newer model since it' has a Twin-H setup, the manifold is from a Hash model, and the overdrive solenoid came from a 50 or later model. When I put the overdrive from a 48 Super Eight in the 48 Commodore, the shift pattern remained the same. Regardless of whether the overdrive transmissions are Hudson-built or Borg Warner, shouldn't I be able to adjust the rod that connects the shifter to the gear stick to get the desired result?0
Forget my mention of the Borg-Warner, you have the pre-1952 cable type, Hudson-built transmissions. I would guess you can adjust the linkage. Maybe some component was reversed or installed upside down or something. Are you consulting the shop manual? (A Step-Down authority should step in here!)
- 85 Hudson 1916 - 1929
- 11 Upcoming Events
- 74 Essex Super 6
- 28.4K HUDSON
- 990 Street Rods
- 72 Hudson 8
- 591 Vehicles
