47 pickup rear end swap?
Have you considered installing overdrive? That would give you flexibility. I assume you're running the standard 4.11 rearend?
fyi,
I have a '53 Spicer rear in my Trk with spacers but had to bend out the inner fender panels slightly since they are wider than the frame rails. I also have a Ford rear End in one because wheels are the same bolt circle and the U Joint interchanges.
- 85 Hudson 1916 - 1929
- 11 Upcoming Events
- 74 Essex Super 6
- 28.4K HUDSON
- 990 Street Rods
- 72 Hudson 8
- 591 Vehicles
