AMC Mechanical Fuel Pump
                    Hi,
I'm replacing my stock fuel pump with an AMC Mechanical Fuel pump on my '51 Hudson Hornet and wanted to see if anyone could help me identify which port is the inlet from the tank and which it the outlet to the carb? I've attached a picture for reference. one port is threaded and the other accepts a rubber line, but no detail is included with this pump to identify which port is which and this pump is setup differently than the stock Hudson pump.
Thanks!
Thanks!
            The one that has the end for a rubber hose is the one from the fuel tank.
Because the engine vibrates and rocks when accelerated, you need some flex in the line because the line from the tank is fixed to the frame.
Hope this helps
Ron0 -
            Poncho68 wrote:
Walt here. The flex line goes to the straight inlet and the threaded end goes to the carburetor. Now this is a must, do not bolt the pump directly to the block for when you start the motor it will break the arm right off. You have to use the gasket pack that was on the original fuel pump or get one and it must be at least 5/16 thick.Hi,
Thanks!0
 - 111 Hudson 1916 - 1929
 - 92 Essex Super 6
 - 178 The Flathead Forum
 - 606 Vehicles
