Spot Welds!!!!
I'm trying to remove the box which is spot welded to the firewall from inside the goes under the cowl and overthe heater. I have found some of the spot welds by wire wheeling the firewall, but apparently i have some missing and I can't see them. Is there some body manual that might show where they generally put the spot welds?
Just get the ones you can see and as you pry of the edge the ones left will "reveal" themselves pretty easily.
Also this may be a double wall area so check the firewall inside the body tub as well.0
- 111 Hudson 1916 - 1929
- 92 Essex Super 6
- 178 The Flathead Forum
- 606 Vehicles
