Removing the locators on a flywheel
They are swaged in. You will have to grind off the projections on the front of the fly wheel before you try and punch them out. Then a spot of mig weld to hole them back in.
Thanks Geoff. On this fly wheel, the projections were recessed so I drilled the tops off - same method as removing spot welds and it worked a treat. I looked at other fly wheels that I have and the projections were raised!
- 111 Hudson 1916 - 1929
- 92 Essex Super 6
- 178 The Flathead Forum
- 606 Vehicles
