Hudson shift lever "anti-rattle washer"
Yesterday I was pulling my '53 Super Wasp into the driveway and to my surprise the control (shift) lever (standard transmission) came loose and almost pulled out from the steering column. It turns out the "control lever fulcrum screw" fell out that attaches the control lever to the steering column. I later found the unique screw on the floor along with the small lock washer. The 1952 Hudson Mechanical Procedures Manual indicates there's also an "anti-rattle washer" that is part of the assembly for holding the shift lever in place with the fulcrum screw and lock washer. Does anyone have any idea what this washer is made of such as rubber or nylon? I couldn't find it and perhaps it wore out and that explains the loose fulcrum screw. Thanks for any response!
Dan
It could be what is called a wavy washer - steel or stainless like regular washer but with curvature - also used to help hold stepdown convertible top bolts - they put some slight pressure holding parts. I bought a large quantity - because they do not sell you one or two. Let me know ID and approx OD and I will send you one or two if I have that size. Gert HETgtkristi0@gmail.com
Thanks very much Gert. I may check back with your regarding this washer.
I have used a thin fibre washer either side which worked.
- 111 Hudson 1916 - 1929
- 92 Essex Super 6
- 178 The Flathead Forum
- 606 Vehicles
