Clutch adjustment problems 1952 Wasp
Hi
I am having big troubles adjusting the clutch on my 52 Wasp . Everytime i adjust the clearance from pedal to firewall to 1 1/4 inches on first use of clutch clearance is back down to zero as that massive spring just pulls it back. Am i doing something wrong? All parts seem to be there the sealing washer and springs.
Thanks
  • Is the swb procedure same as lwb?
  • Exactly the same. What you need to check is the movement from the floorboard, until the fingers contact the throwout bearing.
