2004R Transmission gear selector indicator issue
I have a GM 2004R transmission behind a 308 in my 49 coupe. I am changing the stock Hudson column gear selector indicator to show P R N D L.
The problem I am encountering is the shift lever, when all the way up, is in Park and the pointer is in the correct position. Then when I move the lever down the pointer moves quite a distance until in Reverse. Then it moves a normal distance into Neutral and again a normal distance into Drive. Once in drive the shift lever has reached its end of downward travel and cannot move any further into a low gear.
I'm not feeling much detent action when moving between the gears.
If this is a linkage adjustment issue could someone, please explain how to adjust it?
Or is it another issue? Any help much appreciated.
- 111 Hudson 1916 - 1929
- 92 Essex Super 6
- 178 The Flathead Forum
- 606 Vehicles
