Reverse gone
I have lost reverse in my single lever overdrive trans. I hadn't had it out for awhile and when i went to take it out, clutch was stuck. So without much thought put gearshift in reverse, clutch in and started engine. Made couple light jerks but wouldn't move. Have tried several times to to get it to take reverse but won't. I can out it in reverse position with clutch out and will make slight mushy grinding noise.I'd had trouble with the in/out lever being hung on one position, lever was hung up between overdrive and direct. this action kinda freed it up but won't know for sure til I get the connecting pat the end of the cable. I'd had the cable off the lever for quite awhile. Any suggestions, solutions, guidance, or help?
Thanks in advance ,
Kim
Thanks in advance ,
Kim
