52 Fuel pump bowl mesh screen separated
So I have an issue where the mesh screen inside my fuel pump sediment bowl has separated from the rim (see bowl at bottom of photo). Does anyone know of a replacement or can recommend an epoxy or fuel-resistant adhesive for reattaching?
You don't need an adhesive just the proper cork gasket.0
For the screen, Lance... not the bowl gasket.
I used a bit of "Seal-All" for resealing the screen against the bowl. I have the cork gasket already for the bowl rim. Should be good to go -thanks.
- 111 Hudson 1916 - 1929
- 92 Essex Super 6
- 178 The Flathead Forum
- 606 Vehicles
