Swarf on drain plug
WABOOM
edited October 2022 in The Flathead Forum
Hey guys. I changed my oil today and there is swarf on the drain plug again plug like there was last fall. The magnet is 3/16 by 7/16 long for reference. I have been using 15W40 diesel oil.  I just wanted to run it by the HET brain trust to see what you guys thought. Hopefully my cam is not self destructing. Would you be worried?
  • Thank you
  • In my lifetime experience of Hudsoning I would say that is about normal.  Perhaps you could drop the pan and do a clean out if this is a splasher.   Please change from Diesel oil which now has NO Zinc in it to a good modern motor oil. It's past time to use diesel and the additive package is not suitable to gas engines.
  • Is this an original or rebuilt engine?
    37, Shell Oil told me that their Rotella 15W40 Diesel oil does have zinc. Thats what I use but I would be intrested what you use or suggest of a modern oil?
  • Castro makes a 10w30 that is for older cars and has the zinc. If you can’t find that just use 10w30 of your choice w a zinc additive that you get at the parts stores. Otherwise there isn’t anything wrong w running 15w40 diesel rated oil. This is coming from a diesel mechanic and motor head.
  • Thank you.
    This motor was freshened up in '94.
  • Also, the oil I use is the "Off highway" Heavy Duty Diesel oil, not the new "Low Emissions" oil.
    Hard to tell what was in that pan when you bought it. I think those filings are a bit inconclusive without knowing you started with a clean pan. If you're concerned, drop the pan and clean it out.
